Focus ST170 ECU
Old Jun 27, 2016 | 07:34 PM
kevchard's Avatar
kevchard
Default Focus ST170 ECU
Hi
Can anyone clarify for sure if a 2003 ST170 has an EEC V or is a special circuit board in an EEC V case please?
Kind Regards
Kevin
Old Jun 27, 2016 | 08:42 PM
big_wasa's Avatar
big_wasa
It does not say eecv but it's the same architecture.
Do you want to know for he hard ware or the software ?
Old Jun 27, 2016 | 08:50 PM
kevchard's Avatar
kevchard
Hi
Thank you for the reply, this sort of info is really hard to get hold of.
I bought a 'special force sniper' box that connects to the ECU via the OBD port that fits all Fords from 96 - 06 with an EEC V in (to program out PATS, EGR etc). It wont work on the ST170 and manufacturers say the 4 digit code on my ECU isnt a true EEC V.
It also wont work on my 98 Lincoln MK VIII (mustang 4.6 'intech' EEC V) either because it is running a skinny loom without the SCIL (Pats box).
This is their answer :-
"Ahh, that explains it. Our software does not support a 3NFA calibration. Even though the pcm may be the shell of a EEC-V, the circuitry inside is not. The file in that pcm is 1472kb whereas EEC-V files are 225kb."
I only have their word that they are telling the truth.
Kind Regards
Kevin
Old Jun 27, 2016 | 09:14 PM
big_wasa's Avatar
big_wasa
I've played with lots of these and I havn't seen the eecv printed on the ecu since around 1999.
Old Jun 27, 2016 | 11:18 PM
botters's Avatar
botters
competant bodger
stewart at motorsport developments will be the man for this question im sure
Old Jun 28, 2016 | 02:37 AM
jsa's Avatar
jsa
Post a pic of the label on the ecu and a pic of the guts of the ecu with the lid off.
Old Jun 28, 2016 | 08:37 AM
Stu @ M Developments's Avatar
PassionFords Creator
The 2M5F-12A650-EA is an EEC-Levanta
vanquish Fire
25
Jan 30, 2020 04:45 PM
fury556
45
Dec 13, 2018 11:53 AM
JC600
161
Nov 3, 2016 08:51 PM
andy888
Ford Focus ST
Jun 13, 2016 03:18 PM
Wilde_UK
Ford Focus ST
Jun 3, 2016 04:11 PM
