abs light/brakes on rst
Old May 16, 2004 | 07:44 PM
rabmc's Avatar
rabmc
Default abs light/brakes on rst
My abs light has just come on and is not going of now my cars going in next week to get brakes sorted , but what will i be looking at fixing i have a patch of brake fluid at my rear left wheel when i go out in morning or whenever its sitting and brakes have started to squeek now when pressing ?? so just wondering what the score is with brakes cose im technically challenged in the brakes department , i have willwood 4 pots on front , thatys the only difference in the brakes from standard , and braided lines ,, how much do these types of things cost to fix if anyone
Old May 16, 2004 | 07:54 PM
dave green's Avatar
dave green
It sounds like you need a rear wheel cylinder and rear shoes if fluid has got on them. As for the abs light . all the light tells you that one of the ABS belts have snaped. not expensive belts cost about 12 quid and less than an hours labout to fit it.
Old May 16, 2004 | 08:07 PM
rabmc's Avatar
rabmc
Cheerz m8 , good to no ,,
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
