EEC V Flash e eprom power supply
Old May 16, 2016 | 08:02 PM
kevchard's Avatar
kevchard
Default EEC V Flash e eprom power supply
Hi
Has anyone got an idea of what voltage should be coming off of / going into pin 13 on the EEC V please?
I have a programming box to fiddle with my ECU but i am only getting 0.56v out of the aforementioned pin on my ECU.
I have tried a mondeo mk ii eecv ecu and a 1996 lincoln Mk Viii ECU both with the same results.
This ECU pin goes to pin 13 of the OBD connector.
Kevin
Old May 17, 2016 | 01:39 PM
sailorbob's Avatar
sailorbob
The FEPS pin should normally be close to 0 volts, it's the programming device that supplies the +V to the ecu during programming.
Old May 17, 2016 | 07:05 PM
kevchard's Avatar
kevchard
Hi
Thank you for the advice, that puts my mind at rest that the ECU isnt faulty. I scoured google for hours looking for that info but couldn't find it.
Kind Regards
Kevin
Willywonker007
Aug 2, 2017 07:21 AM
timsrs
May 15, 2016 08:56 AM
BMG
May 11, 2016 09:04 PM
neilnewboy
May 10, 2016 09:11 PM
Dubhghaill
Apr 26, 2016 11:46 AM
