transit 2002 blows indicator fuse
Old May 13, 2016 | 10:26 PM
Blue180's Avatar
Blue180
Default transit 2002 blows indicator fuse
Hi all and thanks for reading this post, i have a transit 2002 and it keeps blowing the indicator fuse, either when hazards are pressed or if i push stick to indicate left turn or even just pushing remote to lock van, so it appears anything that requires left side indicators to be used blows the fuse, any help would be gratefully received. paul
Old Jun 24, 2016 | 12:06 AM
Blue180's Avatar
Blue180
An update,,,,, so i removed all 3 lights on left side and put them back 1 by 1 and as soon as rear light was back on fuse blew, so i bought new rear light and it was working fine except when you press remote locking button the indicator lights used to flash but now dont, i thought i can live with that not a major issue, well 2 days later and the problem was back periodically and just on left side, so i checked rear light again and there was some water in there, probably i thought because i hadnt done light up tight enough, i removed it and dried it out with hair dryer and taped the multi plug up with insulating tape, and great it worked ok for few more days, then it started again periodically, i checked it again today and no sign of water on any of the lights, i removed all 3 lights again and the fuse blows without the lights fitted as soon as i indicate left or even switch on hazards, 40 fuses later im totally baffled. Any ideas would be gratefully appreciated. paul
ehstone
Ford Fiesta
Nov 8, 2016 04:51 PM
Hayzzx
May 13, 2016 07:16 AM
BMG
May 11, 2016 09:04 PM
