Saph Coz rear disc type & size
could anyone tell me for definite which size and type of disc on the rear of a 1988 Saph cos please? so many different sizes being thrown at me and vented an non vented I don't know what to order. I am build the car from scratch so don't have originals to measure etc
Thanks
Thanks
Hi,
2wd were non vented, same as XR4x4.
4wd were vented.
I think I may have some decent but old (maybe only one of each) 4 wd and 2wd discs and 2wd calipers and carriers etc. (pair) here if you want to mock something up. I don't need anything for them but you would need to cover the post as they are heavy unless you travel from Birmingham to Hindhead (150 miles???)
The calipers are in good condition as I refurbished them a while ago.
The hubs on a 2wd are slimmer than on 4 wd too.
The diameters are the same but cannot remember if 256mm or not.
4wd were vented.
I think Parcels to go .com would do it for £10 to £15. I can just let you know the cost if you are happy with that. I am not looking to make any money out of it. If you want to pm me your address I can get it all sorted. I think they need a mobile number too for you.
Resident Wrestling Legend
2wd discs were 273mmx10mm
Callipers were the same as every other Sierra/Granada
4wd were 273mmx20mm and vented
The callipers and carriers were specific to the 4wd cosworth, Granada cosworth and Granada estate
If you have a cosworth 2wd you can directly replace the rear brakes with the 4wd versions with just callipers and disc's, the hubs are the same as it's the callipers lugs that were different to the non cosworth versions
Hi Mate, Ok, I have posted out a 2wd rear disc (bit rough as I used it as a tool for undoing a wheel bearing / hub nut but good enough for mock up. I have included 2 caliper carriers and calipers in good condition. I have pmd you with the cost of the postage, the items are free. I think I have some more brake parts so will let you know as and when I find them. Bigg Red are great for brake parts if you want to replace seals etc. but the posted ones came straight off my car and were working fine.
track.focus'd
12-08-2015 05:53 PM
Graceland
31-07-2015 10:34 AM
