road speed signal
Old May 13, 2004 | 10:09 PM
Fozy's Avatar
Fozy
Default road speed signal
Which pin on the ABS ecu give the road speed signal for the esc cos?
Can't use a wheel sensor coz the signal isn't clean. Ideally need the square wave output from the ECU, unless you know of another wire in the car that emits a road speed signal
Old May 14, 2004 | 06:12 AM
dave green's Avatar
dave green
Ive fited a few sat nav systems. call lm car audio he has a book that tells tou what wire to connect it to
01438 812444
DAVE
Old May 17, 2004 | 09:49 AM
Fozy's Avatar
Fozy
cheers dave
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk22door
23
Oct 2, 2015 10:06 PM
AJC
Oct 1, 2015 06:47 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
