3dr brake wear indicators
Old Apr 4, 2005 | 11:04 AM
B11GNS's Avatar
B11GNS
Default 3dr brake wear indicators
my brake warning light flashes, i have checked the brake pads and they are fine, i also have checked the plugs which are cliped to the calipers and have removed the plugs and shorted the relevent pins to eliminate the plug connections and the wire to the pads. So can only assume its from the plug inwards that there is a problem. Anyone any ideas?
Old Apr 4, 2005 | 03:40 PM
moonstone mike's Avatar
moonstone mike
Ever since i have canged my front pads mine flashes???
how did you get on fitting your coilovers ????....easy ??...happy?
Old Apr 4, 2005 | 04:53 PM
B11GNS's Avatar
B11GNS
doing at the moment, i have the front hubs off as im doing the wheel bearings, they'll be going back on tomorrow and i will putting the avos on in the process. I will do the rears probably next weekend
Old Apr 7, 2005 | 01:58 PM
B11GNS's Avatar
B11GNS
Anyone else help?
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
