brake fluid resevoir wiring on s2 turbo
Old 28-01-2015, 07:30 PM
adt1986
adt1986's Avatar
Default brake fluid resevoir wiring on s2 turbo
Hi all , I'm coming to the end of my project been along time coming but the mot finally book for Monday, my question is the brake fluid reservoir cap has 3 wires go to it to turn the brake warning light off on start up, when I got the car the 3 wires where off the reservoir cap and separated by 3 separate wire clips, I can't find any information in which to find out which wires go where to turn the lamp off , hope to get some help as this is the only thing stopping it going through the mot !!
Thanks you in advance guys
Old 28-01-2015, 07:38 PM
mk2grp1
going sideways in a fwd
mk2grp1's Avatar
from cap brown to earth brown yellow to dash clocks brake indicator brown green to handbrake switch good luck on monday
Old 28-01-2015, 07:42 PM
adt1986
adt1986's Avatar
But in what order do they plug in to the cap , as in looking down on the cap ie Brown on left and yellow brown in middle ?, as a example
Old 28-01-2015, 07:48 PM
mk2grp1
mk2grp1's Avatar
from above with cap fitted brown green left brown yellow centre earth on right
Old 28-01-2015, 07:49 PM
mk2grp1
mk2grp1's Avatar
that's with the caps spades pointing towards the screen
Old 28-01-2015, 07:53 PM
adt1986
adt1986's Avatar
Thanks for the help hopefully the light will go out now then pictures to follow of it all done
original
30-01-2022 08:20 PM
Matt Baxter
16-09-2015 08:30 PM
muz
16-08-2015 12:57 PM
Gadget
13-08-2015 08:19 PM
turbobill
01-08-2015 08:55 PM
Quick Reply: brake fluid resevoir wiring on s2 turbo
