Smart Charge alternator wiring
Old Jan 26, 2015 | 06:38 PM
Matt478's Avatar
Matt478
Default Smart Charge alternator wiring
Managed to get round to wiring my ZT build.
It seems I have a 'smart charge' alternator and after a bit of research it seems they are ECU controlled.
My question is, can these alternators be wired in to run 'as normal' non ECU controlled?
Or are any other types available which will still retain the same mounting bracket, on the back side of a 2.0 black top.
Old Jan 29, 2015 | 10:01 AM
roger69's Avatar
roger69
I was told by my electrician that if you remove the plug from the back of the alternator it will work as a normal one but it must be connected via other terminals to the battery
Old Jan 29, 2015 | 10:12 AM
RichieST's Avatar
RichieST
As above will work as normal if you leave the 3 pin plug unattached.
Old Jan 30, 2015 | 06:49 PM
Matt478's Avatar
Matt478
Thanks for the replies so far, what about wiring for the dash light, can one of the pins be used or would that have been done through the ECU originally?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
jay030787
Sep 18, 2015 04:38 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
