ABS Problem but no warning lights
Old Jan 26, 2015 | 07:58 AM
kiteboystu's Avatar
kiteboystu
No more Alfa's for me...
Default ABS Problem but no warning lights
Hi all,
I'm running a 58 reg Focus 1.8TDci.
Never bee quite sure about my ABS on this car???
I've looked online and on here but not found an answer...
The brakes themselves are fine and work well, but if you need them in an emergency and stamp on them, instead of the usual pedal feedback, you get a sort of funny noise (like a motor whirring fast or gas escaping) and a sort of pathetic little vibration feedback through the pedal?
Oh yeah, and the end results is, you nearly end up in the back of something!
This may be relevant:
Sometimes, after starting the car from cold, just as I head out the end of the drive and brake lightly to look left and right, you hear the same whimpy noise (like somethings re-setting itself)? Doesn't happen every time though.
Ideas anyone?
ABS Pump?
ABS Hydraulics?
Like I say, the actual brakes work fine otherwise, even under heavy breaking, just not when you stamp on them for that all-important emergency stop!!!
Thanks in advance,
Stu
Old Jan 27, 2015 | 06:58 PM
anthony lea's Avatar
anthony lea
Ford allegiance
Originally Posted by kiteboystu
Hi all,
Ideas anyone?
ABS Pump?
ABS Hydraulics?
Thanks in advance,
Stu
Bulb removed?
Clean up all the connections on the sensors?
Old Jan 28, 2015 | 08:04 AM
kiteboystu's Avatar
kiteboystu
Thanks Anthony, let's hope it's something as obvious as this.
It's going into my friendly local mechanic later today - I'll mention this when I drop it off.
Cheers,
Stu
Stu
Old Feb 3, 2015 | 10:18 AM
kiteboystu's Avatar
kiteboystu
My local mechanic is friendly, but also very busy and SLOW to get back to me.
He's driven the car and agrees the ABS isn't right; doesn't seem to kick in properly and pulls to the right a bit.
He said he'd ask a mate at a Ford Dealer for an opinion - that was last Friday!
Chased him for an answer again this morning - he's getting back to me :-(
I need it sorted before I do a 600mile round trip to the Lakes next week!!!
Anybody any ideas PLEASE?
Old Feb 15, 2015 | 09:45 PM
stevieturbo's Avatar
stevieturbo
C**t
If it's bad in the meantime, either unplug an ABS sensor or remove the fuse for the ABS, that should disable it and allow it to function as normal brakes without fear of the ABS doing something silly until you can get it fixed
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
jaysoc1
Aug 20, 2015 08:18 PM
dojj
15
Aug 18, 2015 08:21 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Neatrags
Aug 16, 2015 07:57 PM
