solid lifters, s2
Old Mar 29, 2005 | 08:48 PM
zvhrst's Avatar
zvhrst
Default solid lifters, s2
hi i have a 2.1 zvh conversion and the engine seems to struggle (or not like) revving above, 6000 revs, i have an idea of changing it to solid lifters instead of hydrolic ones, has any 1 ever done this to a turbo?? were the effects better??
any help apreciated.
Old Mar 30, 2005 | 09:07 AM
nthorpey's Avatar
nthorpey
What cam have you got ? Also is the head standard if so its going to have problems consuming all that air
Std ZVH syndrome, its going to need a good head and cam choice to make it rev
Old Mar 30, 2005 | 12:33 PM
rich2302's Avatar
rich2302
You should be able to use the solid tappets from the RS1600i, they do tend to be very noist at high revs, but as said, you need to look at your cam and head work first
Old Mar 30, 2005 | 01:58 PM
zvhrst's Avatar
zvhrst
its got stg 3 head, and piper cam, not sure wat size was sold it buy same company that did my head work, its all ported ploished big valved ect, told them bout problem they recommended to try the solid lifters, but av never heard of any1 puttin them in an rst, dont get me rong it stil shifts but ad jus like that bit extra.
thanx guys
Old Mar 30, 2005 | 02:03 PM
nthorpey's Avatar
nthorpey
I run a Racepower motorsport st3 big valve head, unique cam and 2.1 zetec bottom end, i have solid lifters and double valve springs too. This will rev to 8000
What turbo etc are you running?
Old Mar 30, 2005 | 02:12 PM
zvhrst's Avatar
zvhrst
full spec top to bootom is
head as described above,
stg 3 t3-4 turbo, cossie downpipe 3and half inch zorst, staight thru
lightwieght accralite pistons comp ratio 6.8-1
drop foged rods,
bronze bearings, (floatin bottom end)
lightend crank,
high press oil pump,
then lil things like, chip, burton dizzy ect
oh and engineering company said its bit bigger than 2.1 near enough to 2.2
did you find the solid lifters made a goos increase>?>
what sort of power are you running?
thanx
Prickly_buzz
Dec 7, 2017 09:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gambo08
Feb 4, 2016 10:49 PM
mk1turboestate
Dec 2, 2015 08:31 PM
SMILER258
Sep 28, 2015 09:04 AM
