Cvh ticking, sounding like a scooby
Old Aug 4, 2014 | 08:59 PM
oriont's Avatar
oriont
Default Cvh ticking, sounding like a scooby
I have recently built a cvh 1.9efi and has run ok for few hundred miles so far. However it started to make a noise like a lifter had failed, ticking, got louder and more repetitive with revs and engine sounded rough. Running round town at low speeds not to bad, get on motorway at 70 and after 10 Minster allmity noise as if no oil to top end. Stop engine, leave a few minutes restart and ok until you get up to speed again. So changed lifters and seemed ok for 300 miles but has started again. Checked oil pressure tonight and fine at nearly 60 psi around 3000rpm. Checked cam lifts and whilst not to book figures its not too bad. Piut in an old set of lifters and still the same. Beginning to think it's bad luck coming to haunt me and could be broken piston ring.
Anyone got a view on where to look, what to try?
Dave
Old Aug 4, 2014 | 09:18 PM
tony66's Avatar
tony66
Default noise
when these run ends they sometimes just sound tappety
worth popping sump off for a look
Old Aug 5, 2014 | 05:34 AM
cos 4x4's Avatar
cos 4x4
I had this on my old frst I changed the tappers but still no change turned out to be the exhaust manifold gasket had blown through. Changed ghat and all was well
Old Aug 5, 2014 | 01:19 PM
oriont's Avatar
oriont
Cheers for replys. Definitely some metal to metal going on, only option to open it up, going to put endoscope in plug holes first tonight.
Dave
Old Aug 5, 2014 | 03:41 PM
155lee's Avatar
155lee
Did you bed the cam in?
Had this on a s2,cam lobe was practically round,not oval.
Sounded like a scooby,ran shit and oil was like metal soup.
mk3ste
Oct 17, 2021 10:09 AM
TPM961
Jan 15, 2018 10:50 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Fudgey
21
Sep 30, 2015 06:19 PM
