Please help mk5 zetec s
Old Jun 26, 2014 | 09:12 PM
Zetec s jack's Avatar
Zetec s jack
Question Please help mk5 zetec s
Hello I have a 1.6 zetec s mk5 and I'm having a problem, when I put the key in to ignition all the lights come on as it should but no crank off the starter, I hard wired the starter and it works perfectly engine turns over with no bad noises, but when I use the key nothing. Could anyone help please give me a list of things to try thank you very much...
Old Jul 1, 2014 | 07:08 PM
Richie15's Avatar
Richie15
Does the fuel pump prime when ignition is switched on?
Could be an immobiliser issue
The little red flashing light on the right of your time clock should be a solid light then go out IIRC if it's flashing constantly when ignition is switched on i believe it's an immobiliser issue
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
