Handbrake Problems Escort RS Turbo S2
Old Jun 8, 2014 | 07:46 PM
rsturbo102255's Avatar
rsturbo102255
Default Handbrake Problems Escort RS Turbo S2
I have a headache with the handbrake on my Escort RS. I have just fitted new brake shoes. Simples !
When I re-fitted the drum it turned ok, but when you apply the handbrake it then sticks (alot). So much so that you cannot turn the drum at all (even with a big lever)
It is NOT the self adjuster (it is free and working ok), and the cable is fine. I have repeated the above several times (drum off, turns ok, handbrake on, sticks)
I have checked all the springs and other bits and they are fitted correctly.
The handbrake adjuster (under the car) has been freed right off. Something is just not right !
I am completely baffled folks !
Old Jun 8, 2014 | 08:08 PM
cabriolet's Avatar
cabriolet
possibly wrong shoes or worn drum / oval drum , sticky cable
Old Jun 12, 2014 | 10:01 PM
studabear's Avatar
studabear
Are you sure the cable is ok, have you tried operating the cable with the shoes disconnected?
Whereabouts are you?
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 16, 2015 06:38 PM
muz
Aug 16, 2015 12:57 PM
druidgetafix
Aug 15, 2015 10:22 AM
adriansaleem
Aug 1, 2015 09:28 PM
