ofab map sensor problem
Old May 30, 2014 | 03:46 PM
ozzy69's Avatar
ozzy69
Default ofab map sensor problem
Hello i have a 2.0 zetec turbo running on ofab but the problem i have is the car will not start,run or idol with the map sensor vacum pipe connected but if i take the pipe of she will start,run and rev up! i have tried another map sensor but unsure if the other one was a working one either.
I have searched the interweb and found three other people with the same problem but no cooont was kind anuff to leave the solution to there problem
Please some one help me out.
Old May 30, 2014 | 06:06 PM
ozzy69's Avatar
ozzy69
Problem not solved been told from a lad that he had the same problem and turned out to be fueling so will try this next.
Old May 31, 2014 | 08:28 PM
ozzy69's Avatar
ozzy69
still no joy i swaped the ful reg today as another lad had that problem but still no joy i am getting alot of black soot and smoke also can anyone help as am close to torching it.
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
mike elsome
Sep 14, 2015 04:08 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
