AP Racing Master Cylinder Help
Old May 5, 2014 | 05:49 PM
Billy_RS's Avatar
Billy_RS
Default AP Racing Master Cylinder Help
I need help on which size bore I need on my car?
How does it work? The smaller the bore the less fluid is pumped? So the bigger the bore the more fluid is pumped?
Im a newbie when it comes to the braking system
Billy
Old May 5, 2014 | 08:03 PM
jon@work's Avatar
jon@work
what do you want it to do?
Old May 5, 2014 | 08:07 PM
Billy_RS's Avatar
Billy_RS
Ideally to stop the car when I push the middle Pedal
Jokes aside, I'm going to make my own pedal box system because I have a serious lack of space to use a standard size servo etc
So need to find out what size bores to use etc as I dont want to get balls deep only to find that I have the wrong Master Cylinders
Billy
Old May 8, 2014 | 06:40 PM
porterste's Avatar
porterste
smaller the bore means more pressure IIRC
Old May 8, 2014 | 07:02 PM
nixon_2wd's Avatar
nixon_2wd
Smaller bore means less force acting on the pedal, because P=F/A. P should be constant, so smaller A means smaller F to keep P the same. Thats why a smaller bore master cylinder gives you a lighter pedal and longer travel than a large one.
A smaller bore cylinder have less volume which means you need to push the piston further to move the same amount of fluid as a larger one.
Old May 8, 2014 | 07:04 PM
Billy_RS's Avatar
Billy_RS
Argh! My brain!
Ok I follow you I think, so would I use a smaller bore for the fronts and a larger bore for the rear?
Billy
Old May 8, 2014 | 07:19 PM
nixon_2wd's Avatar
nixon_2wd
That depends on your caliper pistons (slaves). You should most likely use two equally sized mcs and then its only a matter of adjusting the brake bias (a lever which controls the stroke distribution).
The only reason for using a bigger mc is when your stroke is limited or if you experience very long pedal travel, mainly due to additional pistons on large brake setups.
Nov 1, 2015 06:53 PM
The Youth.
Sep 30, 2015 09:59 PM
muzzman1
Sep 30, 2015 08:59 PM
