escos chip
Old May 9, 2004 | 07:30 PM
AJ Escos's Avatar
AJ Escos
Default escos chip
can i just remove the chip or is there anything else i need to do
Old May 9, 2004 | 07:41 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
i think so m8 i take it the car is a eeciv car not a marelli car if so yes
Old May 9, 2004 | 07:53 PM
AJ Escos's Avatar
AJ Escos
car is eeciv m8, have been having problems that i couldnt figure out but after getting a code reader on it it seems its been chipped which i knew nothing about,checked today and it has been chipped so im hoping that is the root of my problems (fingers crossed), cheers for the info m8
Old May 9, 2004 | 08:13 PM
Billabong's Avatar
Billabong
What's actually the problem Andy?
Old May 9, 2004 | 09:41 PM
AJ Escos's Avatar
AJ Escos
To start with it had a problem with one of the relays clicking (small blue one) slow then faster as the revs got higher this seemed to cause a misfire, then all of a sudden it would stop pick up again and throw out a ploom of black smoke(overfueling) . so i had a fault code reader put on it and it came up with the codes 01,31,81 put a thread up as i had no tech data on the codes and stu said 01, doesn't exist 31 was "memory failure so its chipped with some problem" and 81 was "egr valve dont ask ". So tonight after reading this i thought i would check the ecu as wwhen i bought the car the guy said it was standard it fookin wasnt so ive now taken chip out and the car is running better than ever so it seems all sorted now but thanks to everyone for the help
Old May 9, 2004 | 09:49 PM
Stu @ M Developments's Avatar
PassionFords Creator
The memory will need to be wiped clean mate.. make sure thats done asap or it will be running on the wrong base strategy.
Old May 9, 2004 | 09:52 PM
AJ Escos's Avatar
AJ Escos
wrong base strategy and that means? sorry Stu but mechanical i can deal with electronics im lost with m8
Old May 9, 2004 | 10:17 PM
Basically, the ECU learns the best settings for various conditions, programs this to the ecu and then runs from this new "Base strategy"
Ther settings its using will be related to the chip you had fitted, so it should ideally be reset.
Old May 9, 2004 | 10:29 PM
AJ Escos's Avatar
AJ Escos
will it be able to be reset by the fault code reader stu?
Old May 10, 2004 | 09:31 AM
Depends on its technical capabilities, good ones can do it, yes, they are in fact the only way to do it.
Old May 10, 2004 | 10:52 PM
davidreader5's Avatar
davidreader5
stu,
can you confirm that the escort cosworth EEC4 is a two digit code ecu, as
the above seem two indicate this, as i thought may be 3,digit.
Dave
Old May 11, 2004 | 11:56 AM
Dave Henshall's Avatar
Dave Henshall
TO CLEAR TO KAM on a eeciv, just leave the battery disconnected for around 10 mins, then let it idle for 2 mins, then 2 mins at fast idle (1500rpm) then drive for 5 miles to complete its learing process - this is stated in the cosworth workshop manual and IS NOT for webber/martelli equipt cars.
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
A.t.p
Sep 29, 2015 05:04 PM
Mickeystewart
Sep 9, 2015 04:04 PM
