ABS system
Old Apr 20, 2014 | 12:50 PM
cozi500's Avatar
cozi500
Default ABS system
Does the ABS ecu module store codes and go into fault mode, do they reset them selves when power is off. Cant find anything on the web regarding the cosworth ABS ecu or faults
Old Apr 20, 2014 | 02:14 PM
martysmartie's Avatar
martysmartie
It's volatile, i.e. when power is lost so are the codes.
Martin
Old Apr 20, 2014 | 02:33 PM
cozi500's Avatar
cozi500
thanks for that so i dont need a reset, must be my pump then, as the pump runs continuously and wont build any pressure to bleed the brakes and the low pressure warning light is on ie handbrake light.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
