ABS system
Old Apr 18, 2014 | 06:02 PM
cozi500's Avatar
cozi500
Default ABS system
Ive posted several times about an issue i have and no one has come up with a fix as yet. It all started when my low pressure pipe split from the reservoir to the pump. Since replacing it, the pump wont stop running and the brake light is on meaning low pressure. i have pressure bled the system and have fluid coming out, however the pump continues to run, i have swapped the relay still no joy, dont seem to build any pressure. could it be the pressure switch faulty im running out of ideas. Anyone
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
