Cosworth boa v6
Old Feb 20, 2014 | 05:13 PM
Sapphcosv6's Avatar
Sapphcosv6
Default Cosworth boa v6
Hi all bought a sapphire cosworth shell and decided to fit a 24 v in it with xr4x4 running gear, having a nightmare getting it started even after pouring over the tinternet for hours !! Ive got the following on it, any advice gratefully received!!engine is cranking, ive got a spark, pin 8 on edis has 12v all injectors have 12v ,coil pack has 12 v ecu is priming fuel pump on initially and when cranking, have fuel up fuel rail, maf has 12 v , pin 37 and 57 on ecu is switched live, pin 1 is perm live,ecu pins 20 40 and 60 are ground, have checked injector plugs for continuity but not hearing initial click from injectors or anything from that area , any ideas ,im ready to push this into the nearest canal its getting on my nerves now 😡
Old Feb 20, 2014 | 05:47 PM
matcossy's Avatar
matcossy
EARTH ?
Old Feb 20, 2014 | 06:05 PM
Sapphcosv6's Avatar
Sapphcosv6
Originally Posted by matcossy
EARTH ?
edis 6 , coil pack, and ecu earthed and ecu pulsing earth to injectors as they have a permanent 12 volt and the ecu switches the earth to the injectors.
Old Feb 20, 2014 | 06:28 PM
dojj's Avatar
dojj
Resident Wrestling Legend
cps failure?
Old Feb 20, 2014 | 06:39 PM
Sapphcosv6's Avatar
Sapphcosv6
Ive been told that because im getting a spark the crank position sensor must be ok, going to spray some easy start in intake to see if it runs on that
Old Feb 20, 2014 | 08:31 PM
dojj's Avatar
dojj
and the plug leads are on the correct plugs yes?
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
