Underheating S2 RST
Old Mar 25, 2005 | 12:59 AM
starturbo's Avatar
starturbo
Default Underheating S2 RST
My rs doesnt get hot enough and no one seems to have a clue whats wrong.On the normal (std) gauge and an aftermarket one which is plugged into the top hose,the temps are low.The aftermarket one shows 50 deg C and the heater blows warm.Not warm enough at 3 in the morning.I have changed the thermostat and it made no difference.If the heater matrix was blocked then I would expect the engine to run hot because the water cannot circulate can it?The only thing I have noticed is that when you unscrew the header tank cap there is no pressure so I bought a new one which has made bugger all difference.I am concerned that the oil temp might get high as today I noticed on the motorway that the oil temp went to 90 deg C.Never seen it that high.In a nut shell the warm air from the heater confirms what the gauges are telling me but what the hell can it be.Oh and the control rods to the heater flaps are all ok?any ideas please guys?
Old Mar 25, 2005 | 06:25 AM
starturbo's Avatar
starturbo
Anyone?pleeeeeze.
Old Mar 25, 2005 | 08:36 AM
Arjan's Avatar
Arjan
-The aftermarket one shows 50 deg C
-when you unscrew the header tank cap there is no pressure
-the oil temp went to 90 deg C.Never seen it that high
seems to me like yr waterpump is broken
Old Mar 25, 2005 | 09:14 AM
starturbo's Avatar
starturbo
If it was the water pump wouldnt it overheat?
Old Mar 25, 2005 | 09:24 AM
wayniac's Avatar
wayniac
for what it costs.. Id swap water pump anyway... then flush the pipes out with a garden hose in both directions.
hope you sort it matey
Old Mar 25, 2005 | 09:25 AM
Arjan's Avatar
Arjan
likely, but overheating generates pressure and steam from out the header cap..
Old Mar 25, 2005 | 11:01 AM
escortrsmatt's Avatar
escortrsmatt
my car appeared that it ran cold all the time and the temp gauge sender unit was fooked.
Old Mar 25, 2005 | 01:32 PM
starturbo's Avatar
starturbo
I have 2 gauges and they say the same.There is one each side of the thermostat.Just let it run on the drive and the fan is cutting in?Must be fooked gauges and a blocked heater matrix and possibly a pump.
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
`spotty
Sep 25, 2015 11:41 PM
Billy_RS
Sep 13, 2015 04:17 PM
