L8
Old Feb 7, 2014 | 12:10 PM
shortie's Avatar
shortie
Default L8
Can I use an L1 loom from a 3dr cosworth on an L8 for the same car
Old Feb 7, 2014 | 12:34 PM
rog's Avatar
rog
http://www.bigturbo.co.uk/main6.htm
Yes, check the diagrams, as far as I know it's only the TPS that's different, swap the outer two wires over.
Old Feb 17, 2014 | 07:18 PM
matcossy's Avatar
matcossy
what about the knock sensor and o2 sensor?
are you no going to run them as well??
Old Feb 18, 2014 | 04:17 PM
opposite lock's Avatar
opposite lock
Looks like it can be done using knock and lambda still but you would need to wire these in to the correct pins 6,22 knock control and 2 for lambda.
