Zetec Auto to Manual ECU.
Old 07-01-2014, 11:52 PM
power047
power047's Avatar
Default Zetec Auto to Manual ECU.
Hi.
Im currently doing a mk1 escort project which I intend to fit a zetec.
i have a 2.0 mondeo GHIA Auto which has done 41k running the EEC-V ECU with the PATS system. the engine is in good condition.
I intend to put the engine into the escort running the standard ford ECU system. I want to do this as its cheap, reliable and fast enough for me,
I think understand the issues surrounding PAT's system.
But
I am looking for advice on the issues which the AUTO ECU will cause for me as I am planning to fit it to a manual gearbox
as far as I can make out I know I need to swap the Crank Position Sensor Mount for a manual one.
But that's about as much as I know for sure.
I'm aware some Pins need changing/Bypassing/resistors installing to allow the car to start and rev in neutral/drive and to prevent the fans continually going. but i dont know which or where.
The engine at wont rev above 4k unless its in drive, will this cause an issue
some things i've read said it cant be done others it can, some advice on what needs to be would be genuinely appreciated.
Thanks
Oli.
mk3ste
17-10-2021 10:09 AM
arkeye
Ford Focus ST
20-02-2016 01:22 PM
AJC
01-10-2015 06:47 PM
stevecfrst1
30-09-2015 05:18 AM
mondeomark
28-09-2015 06:28 AM
Quick Reply: Zetec Auto to Manual ECU.
