LED brake light
Old Dec 1, 2013 | 03:35 PM
Brendonavoo69's Avatar
Brendonavoo69
Default LED brake light
Hi
I have ford focus mk1. I have just replaced the 3rd brake light with a clear Lexus style LED light, but it doesn't seem to work. The connection is exactly the same as the previous light. The only difference is that it's LED.
Any ideas why it won't work?
Old Dec 1, 2013 | 03:53 PM
William MK2 Cosworth's Avatar
As a led light, you should check the polarity first.
if you connected it with a pair of wires, just swap them over
Old Dec 1, 2013 | 06:55 PM
Brendonavoo69
So is it a case of connecting the red wire from the light to the black wire on the car, and vice versa?
Old Dec 2, 2013 | 02:47 PM
if you can get a hold on a multimeter you can try to find which wire is positive and connect it to the red wire on the led.
The only way a car "might" have a black wire for positive is if it has all its negatives a different color. On old fords the negatives were brown, but I have no idea what colors your car has.
Because the led is as its name suggests (Light Emitting Diode) is a diode, if it is connected the wrong way, no harm will be done, but it wont work.
yatta
May 21, 2016 10:31 PM
Kam B
Sep 24, 2015 10:40 AM
focus2351
Sep 9, 2015 09:33 PM
fuzzy
Sep 4, 2015 10:11 PM
hopper350
Sep 4, 2015 12:53 AM
