indicator relay info needed
Old Nov 27, 2013 | 04:05 PM
andy escos's Avatar
andy escos
Question indicator relay info needed
as title i will be getting the mk2 escort rewired by Richie from scratch but im not using the indicator stalk ,i will be fitting latching switch,s on the steering wheel & i want to use both indicator switch,s at same time for hazards .
The question is do i use a 2 pin indicator relay or a 3 pin relay
ps i will be using led bulbs through out if that makes any difference.
thanks for any help.
Old Nov 28, 2013 | 07:11 PM
andy escos's Avatar
andy escos
Bump
Old Nov 28, 2013 | 07:21 PM
costina's Avatar
costina
Live long and prosper!!
Andy you will need a led flasher unit for starters A.E.S do one about £15
Tbh the way you want to do it can't be done. but I will have a think.
So you want to run a pair of switches on steering wheel one for left one for right correct?
Old Nov 28, 2013 | 07:23 PM
costina's Avatar
costina
http://www.autoelectricsupplies.co.u...26/category/35
Old Nov 28, 2013 | 07:25 PM
costina's Avatar
costina
Live to flasher via fuse to switches from switches to left and right indicators to earth.
Remember leds will only work with correct polarity
switching both should give you hazards
Old Nov 28, 2013 | 07:34 PM
costina's Avatar
costina
3 pin has output for indicator warning light
Old Nov 28, 2013 | 07:45 PM
andy escos's Avatar
andy escos
spot on thanks mate
jessie_rs
11
Jun 3, 2019 04:57 PM
cos elle
Sep 1, 2015 06:48 PM
kosienutter
31
Aug 22, 2015 09:55 AM
RIB1122
Aug 12, 2015 08:51 PM
col93saphcos
Aug 7, 2015 03:21 PM
