cosworth original 4wd lambda sensor wires?
Old Nov 26, 2013 | 01:17 PM
Thanasis's Avatar
Thanasis
Default cosworth original 4wd lambda sensor wires?
Hello to all,i would like to ask about cossie 4wd lambda sensor wires,so it have 3 wires,one black,one white and one red,so does anyone know where is gone each one? thanks in advance
Regards
Thanasis
Old Nov 28, 2013 | 07:54 PM
costina's Avatar
costina
Live long and prosper!!
red live feed usually from fuel pump relay
black earth
white is signal from pin 2 ecu
Old Nov 28, 2013 | 08:33 PM
Thanasis's Avatar
Thanasis
Thank you very much for your reply.
Old Nov 28, 2013 | 08:50 PM
James @ M Developments.'s Avatar
Black is signal, goes to brown/white on the oe loom
White is ground
Red is 12v
Old Nov 28, 2013 | 09:00 PM
costina's Avatar
costina
Thanks James there is so many different combos
Old Nov 28, 2013 | 09:05 PM
Thanasis's Avatar
Thanasis
Thank you James
kosienutter
31
Aug 22, 2015 09:55 AM
muz
Aug 16, 2015 12:57 PM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
