Amal valve
Old Mar 20, 2005 | 09:05 PM
Filthy Rich's Avatar
Filthy Rich
Default Amal valve
Hopefully someone can help ?
I have a 2wd saff cos and has devoloped a boost problem i think it is the amal valve but not sure? It should hold 23.7 psi,i have a didgital boost gauge that works fine,but the boost is suddenly all over the place will run perfect then drop boost to any level (say 11psi) come back on drop to (say 16psi) (you don't need the gauge to know ,you can feel it)come back hit overboost etc.The connections seem ok, if you unpulg the wires then plug them back in the valve will click,does this sound like a knackered amal valve??
Main problem is that i'm off to the ring on thursday and have 3 14 hour shifts to do before then.
Thanks for any help or advice
Rich
Old Mar 20, 2005 | 11:01 PM
abdr500's Avatar
abdr500
sound like your actuator is letting go thats what it is m8
Old Mar 23, 2005 | 05:23 PM
leesrs240's Avatar
leesrs240
Its the amal valve mate it will have a dodgy conection inside if you woble the wires you will here it clicking...
Belive me i know that is what the problem is..
Old Mar 23, 2005 | 09:41 PM
Filthy Rich
PMSL @ Lee, yep we know what the problem was but it took a lot of stella to find it
steve.rst
Mar 15, 2016 08:01 AM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
rs_jim
Sep 19, 2015 08:41 PM
