amal valve question
Old Aug 26, 2013 | 07:51 PM
RIB1122's Avatar
RIB1122
Default amal valve question
if the amal valve was knakerd or had the wires on the wrong way would that cause you not to get any boost?
Old Aug 26, 2013 | 07:59 PM
BIL N KEL's Avatar
BIL N KEL
Don't think it matters about which way round the wires are but if it was broken you would only see actuator pressure
Old Aug 26, 2013 | 08:02 PM
RIB1122's Avatar
RIB1122
ok, it must be knackered cos only making .8 boost is there a way to test them?
Old Aug 26, 2013 | 08:06 PM
BIL N KEL's Avatar
BIL N KEL
When you turn the ignition on it should click. I think just remove n refit the plug should make it click too when ignition is on
Old Aug 26, 2013 | 08:18 PM
GVK.'s Avatar
GVK.
Check resistance of the valve with an ohmeter 20-50 ohms across the terminals.
I have a question , why is it called an 'amal' valve?
Old Aug 27, 2013 | 12:59 PM
martysmartie's Avatar
martysmartie
Because that is where they were made in Sweden, I really should get out more.
Martin
Old Aug 27, 2013 | 01:00 PM
martysmartie
Sort of, it will only do so when the engine is running, re disconnect/reconnect.
Martin
Old Aug 27, 2013 | 04:57 PM
GVK.'s Avatar
GVK.
Cheers Martin
I did wonder if the British carburettor manufacturers 'Amal' made them.
steve.rst
Mar 15, 2016 08:01 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
rs_jim
Sep 19, 2015 08:41 PM
richierich1986
Sep 18, 2015 03:29 PM
