YB alternator connections
Old Aug 23, 2013 | 12:13 PM
jamie956's Avatar
jamie956
Default YB alternator connections
Need help with the connections on a 2wd 90amp alternator, There are 4 connections. Being fitted into a mk2 Cortina not a cossy.
B+ large stud, assume connect to battery
D+ Medium stud, assume connected to loom
W small stud, ? Warning light at a guess
+ spade terminal, ?
Was planning on connecting the B+ to the starter supply wire to join the main battery cable, after that not sure what needs to be connected where.
Old Aug 23, 2013 | 12:30 PM
martysmartie's Avatar
martysmartie
Correct on the first one.
'D' is for the warning light.
Martin
Old Aug 23, 2013 | 07:36 PM
jamie956's Avatar
jamie956
Anyone got an idea on the other connections.
Old Aug 23, 2013 | 07:55 PM
cabriolet's Avatar
cabriolet
right fella the b+ is battery lead .the d+ is the warning light.the w is a rev counter take off .the + is for a radio surpressor
Old Aug 24, 2013 | 10:04 AM
martysmartie
I have told you what you need, the other connections are not needed, you should really have a supressor though.
Martin
jonfoc
16
Sep 11, 2018 05:35 PM
Mark RS
Oct 12, 2015 06:01 AM
stevecfrst1
Sep 30, 2015 05:18 AM
jay030787
Sep 18, 2015 04:38 PM
