AB07 vs BD14 inlet cams
Old Aug 11, 2013 | 01:27 AM
mitchymitch's Avatar
mitchymitch
Default AB07 vs BD14 inlet cams
as the post says advice please especially on piston formats and if they're similar in performance ie can they be used with standard pistons many thanks in advance
Old Aug 17, 2013 | 11:19 AM
mitchymitch
can anyone help with this?
Old Aug 17, 2013 | 11:50 AM
RS_Driver's Avatar
RS_Driver
Bd14 you have to use Pistons with valve cut outs.... But the AB07 is useable with oe pistons....
Old Aug 17, 2013 | 11:52 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
As above
No piston mods required for the AB07
Steve
Old Aug 17, 2013 | 12:02 PM
lee2cossies's Avatar
lee2cossies
Which would be best on a nice useable engine on t34 or t38? I have valve cut outs.
Old Aug 17, 2013 | 12:53 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
If you have valve cutouts you might as well use a better cam.
Speak to Tony @ Turbosystems
Steve
Old Aug 17, 2013 | 01:00 PM
XR4iSilver's Avatar
XR4iSilver
Used my bd14 with the cut outs and t34.63 loved it taken of now and rebuild with Ahmed spec so got that floating around does anyone NOT A FOR SALE POST know the value of these at the mo ?
Old Aug 17, 2013 | 01:25 PM
Leyleeroy's Avatar
Leyleeroy
I have just fitted one to my escort with 55 siemans and a t34.63 and its making good power i hope to be around the 400BHP. But if you have the head off and piston out you might as well get them pocketed and go with bd14 as it is a better cam.
Old Aug 17, 2013 | 02:43 PM
mitchymitch
Many thanks for the replies i have low comp pistons fitted that have indents in them they look just like this pic(only used to illustrate what mine look like)
http://i.ebayimg.com/t/Peugeot-106-GTi-Citroen-Saxo-VTS-Low-Compression-Pistons-Rods-Various-Sizes-/00/s/NjAwWDgwMA==/$T2eC16NHJGwE9n)ySfb8BQgCMWcfQQ~~60_58.JPG
do's this count as valve cut outs?
on a different note ive searched these forums to death and is it a secret where you can buy the AB07 cam, no one will say where they got them from.
Old Aug 17, 2013 | 04:39 PM
Leyleeroy's Avatar
Leyleeroy
I got mine from burton power just a few month ago, if you ring up kent cams they will tell you where there is a retailer in you area.
Old Aug 17, 2013 | 04:52 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Tony @ Turbosystems can supply the cam
Steve
Nov 1, 2015 06:53 PM
