Rs 2000 Emmission Problems
Old Aug 8, 2013 | 09:54 AM
kleensweeper's Avatar
kleensweeper
Default Rs 2000 Emmission Problems
Hi, Looking for some advice please regarding emmissions on my Mk5...took her for an M.O.T yesterday & only failures were a collapsed drivers side engine mount, 1 x split driveshaft boot & 3 x the allowed emmissions level...apparently if she'd been registered a day earlier it wouldn't have even been a requirement of the test (31/7/92)!! Just wondered if anyone else has encountered the same problem or can suggest any possible causes other than the cat...cash is a bit short at the moment so can't really afford trying one 1st!! - Thanks in advance.
Old Aug 8, 2013 | 11:03 AM
oldford's Avatar
oldford
What are the exact figures for the emissions test?
How much CO, HC, etc.
Old Aug 8, 2013 | 11:12 AM
RichieST's Avatar
RichieST
Yes, need to know the exact figures given, could be anything really, oil burning, over fueling, lambda sensor problem, failed cat, exhaust leak, inlet leak etc etc.
Old Aug 8, 2013 | 02:52 PM
kleensweeper
Sorry guy's have the test results to hand now...both failures are CO figures...Fast idle test is currently 0.88% & Second fast idle reading is 0.90%. Both results should be no more than 0.30% so there quite some way out at present, any suggestions would be much appreciated.
Old Aug 8, 2013 | 03:54 PM
oldford's Avatar
oldford
Without any other figures: defective catalyst.
Old Aug 8, 2013 | 04:49 PM
the_frozen_one's Avatar
the_frozen_one
CO isn't a cat issue. Nox and HC would be a cat issue. Service it, new plugs and filters inc fuel, oil etc put a tank of branded super in it, maybe some injector cleaning snake oil too. Thrash it about a bit to clear it all out and take it back for a retest red hot. It's basically it's running a tad rich (too much fuel), but only slightly, so not enough to send your HC over the limit, do you have any mods? The above is to try an increase combustion effiency to get that wee bit of spare fuel burnt and bring the co down.
gambo08
Feb 4, 2016 10:49 PM
DAZZER
Sep 30, 2015 08:43 PM
little bram
Sep 27, 2015 07:45 AM
