Cossie Misfire
Old Mar 19, 2005 | 12:14 PM
Simmo's Avatar
Simmo
Default Cossie Misfire
got a slight misfire on saff when you plant the throttle at low revs (when you would normally want to change down a gear), a sort of hesitation. But its fine when it comes on boost. Also is lumpy on idle and jumps about a bit when holding say 2500-3000rpm. Fuel consumption's got worse as well, smells so rich!!! Only change coil, leads, plugs, cap and rotor arm recently....
Old Mar 19, 2005 | 01:00 PM
pjdunc's Avatar
pjdunc
what plugs did you put in also sound like its runing rich. i found that ford pp8 plugs work well in mine its running 350bhp
Old Mar 19, 2005 | 01:04 PM
swerv's Avatar
swerv
i would not run these plugs in that spec, know a few people who have had very bad experiances with them!!
Old Mar 19, 2005 | 04:18 PM
Simmo's Avatar
Simmo
the plugs are NGK 8ES ones, same as what came out... i put the old plugs back in and made no difference (misfire's only started recently). just looked at phase sensor and rubber insulation has totally come off one of the wires... leaving them both bare... so could be touching each other or shorting on the dizzy casing!!!
Old Mar 19, 2005 | 05:22 PM
mike77cos's Avatar
mike77cos
That could do it, what about the wires to the crank sensor, they ok?
Old Mar 21, 2005 | 06:24 PM
Simmo's Avatar
Simmo
haven't looked... will look tomorrow when i put the new phase sensor on! cheers for the suggestion!
Old Mar 23, 2005 | 07:09 PM
Simmo's Avatar
Simmo
put new phase sensor on today. made it idle more smoothly but has made no difference to misfire/hesitation on full throttle at low revs!!!! have looked at TDC wiring and looks fine. its still running very rich... could it be overfuelling???
Old Mar 23, 2005 | 07:16 PM
mike77cos's Avatar
mike77cos
Yes, any black smoke?
Old Mar 23, 2005 | 07:38 PM
Simmo's Avatar
Simmo
yes... my dad was following me the other day and said there was black smoke and smelt very rich! can't see it clearly from the drivers seat though!
Old Mar 23, 2005 | 07:42 PM
mike77cos's Avatar
mike77cos
Its rich! most certainly
Old Mar 23, 2005 | 07:50 PM
Simmo's Avatar
Simmo
its only started doing it since i've upgraded coil, leads etc. wondered if it could be something else making the ECU overfuel to compensate... before i go looking into replacing fuel pressure reg etc. what are the main causes of overfuelling? cheers for all your help by the way!
Old Mar 23, 2005 | 07:53 PM
mike77cos's Avatar
mike77cos
Check the map sensor, wiring, air filter (off chance) anyone been playing with the co screw for a laugh? were the leads good quality?
Old Mar 23, 2005 | 08:02 PM
Simmo's Avatar
Simmo
ok will do... not much to check on map sensor though is there?! nobody would have touched the co screw as far as i know! leads were ford motorsport 909 ones. also changed plugs, cap, rotor arm and fitted groupa coil...
Old Mar 24, 2005 | 02:54 PM
jon@work's Avatar
jon@work
if it's running rich, the obvious thing to change is the water temp sensor at the back of the head on the pass side - the 2 pin AMP plug under the inlet manifold just by the water pipe from the modine.
Old Mar 24, 2005 | 06:21 PM
Simmo's Avatar
Simmo
ok cheers i'll renew that when i get the chance... i've booked it into Power Engineering anyway now...
Old Mar 28, 2005 | 03:00 AM
cossiedaz's Avatar
cossiedaz
i have had similar problems with sticking and leaking injectors recently, its a nightmare, good luck fella
mite be worth u popping the injectors out and taking em to someone with a ASNU machine and get em cleaned and flow tested
ive had my car 2 years and been through 3 sets of injectors, showing the symtoms that yours is showing and worse.
like i said good luck
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
