Cosworth Only 0.2 bar boost
Old Jul 18, 2013 | 09:02 PM
RIB1122's Avatar
RIB1122
Default Cosworth Only 0.2 bar boost
got my cossy running in my mk 2 escort, but on the boost gauge im only getting 0.2 bar boost.
Is it a question of adjust the actuator or amal valve problem?
Old Jul 18, 2013 | 09:13 PM
The Youth.'s Avatar
The Youth.
pressure test the inlet system first my guess is there is a boost leak somewhere, check all the connections specially the throttle body one it's easy to fit it with the bottom section not over the throttle body correctly
steve
Old Jul 18, 2013 | 09:17 PM
RIB1122's Avatar
RIB1122
ive checked that today and no leaks!
Old Jul 20, 2013 | 06:09 PM
William MK2 Cosworth's Avatar
when you tap the throttle can you hear the amal valve clicking?
if it stays permanently off, you will only have that much boost, i.e. if the ecu thinks something is wrong
Old Aug 30, 2013 | 04:42 PM
RIB1122's Avatar
RIB1122
right, im on with this problem at the weekend.
Amal valve 29 ohms across the terminals
Turbo was working fine on the car i got it off
new actuator
little video of the boost gauge here -
Old Aug 30, 2013 | 05:37 PM
GVK.'s Avatar
GVK.
Am I being daft here but are you trying to get boost with it stationary?
Old Aug 30, 2013 | 05:42 PM
RIB1122's Avatar
RIB1122
the back end is up in the air! so it is driving but going nowhere!
Old Aug 30, 2013 | 05:45 PM
GVK.'s Avatar
GVK.
There's no load on the engine though.
Can it be driven? If so.. drive it and see what you get.
I don't think you'll get boost with it driving in mid-air.
Old Aug 30, 2013 | 05:56 PM
7sean7m7's Avatar
7sean7m7
Have you tried to actually drive it and see?
Old Aug 31, 2013 | 05:38 PM
RIB1122's Avatar
RIB1122
the problem is its a track car, stickered up with no tax or mot!!!
When i did drive it - no boost!
would you still get boost with it free wheeling in the air?
Old Aug 31, 2013 | 05:47 PM
GVK.'s Avatar
GVK.
I don't think you can get boost without load on the engine (ie stationary or in mid air) happy to be proven wrong though.
Old Aug 31, 2013 | 06:05 PM
botters's Avatar
botters
competant bodger
try it with the handbrake on lol (dont!)
Old Aug 31, 2013 | 06:23 PM
GVK.'s Avatar
GVK.
PMSL, I nearly burnt the clutch out on a Passat on a 4 post ramp doing that trying to find a boost leak
Old Sep 1, 2013 | 11:09 AM
RIB1122's Avatar
RIB1122
right i will risk it later!!!
gchristophi
Aug 31, 2015 10:36 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
costina
18
Aug 25, 2015 06:02 PM
Neatrags
Aug 16, 2015 07:57 PM
Aug 14, 2015 07:29 AM
