Ford Focus ST170 Front Heated windscreen not working
Old Jul 12, 2013 | 10:13 AM
robotechnics's Avatar
robotechnics
Default Ford Focus ST170 Front Heated windscreen not working
Back in the winter a stone chip in my front windscreen turned into a nasty crack.
Before this happened my heated windscreen used to work and when i pressed the button i'd get a light indicating it would be on.
After this crack it no longer worked so just blamed it on the crack.
I've just had a new heated windscreen put in and this still isn't working.
I've checked the manual and there isn't a fuse or relay which is marked as "Front heated windscreen"
There is however:
Fuse 49  Rear Defrost
Relay 25 Rear Defrost Heated Mirrors
Does anyone know if there is a specific fuse or relay for the front windscreen? Or have fixed this problem?
Thanks
Old Jul 12, 2013 | 07:02 PM
RichieST's Avatar
RichieST
You checked its plugged in properly? Not uncommon for the terminals to corrode and drop off.
Old Jul 12, 2013 | 09:29 PM
martysmartie's Avatar
martysmartie
Do you get a 'click' when you switch it on? If not then the relay is not operating. Also check the said connections.
Martin
track.focus'd
Aug 12, 2015 05:53 PM
taylora1409
Aug 12, 2015 12:06 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
