Mondeo 05 TDCI 115 Stalling
Old Jul 11, 2013 | 12:19 PM
howdencomputers's Avatar
howdencomputers
Default Mondeo 05 TDCI 115 Stalling
Hi Guys: Basically after a few weeks of driving with my faults I can give definative symptoms.
The longer I leave the car the harder it is to start, If its left overnight for say 12 hours it will sometimes start after a few cranks but more often than not I have to put it in reverse then crank the engine, then it will slowly fire up, it then runs on rough idle for about 10 mins.
Once im away and driving if I keep the revs high so say keep every gear on at least 2000 revs the car is fine.
If I try to take it easy then it will randomly stall ECU cuts engine, I dip clutch and immediately fires straight back up.
This also happens on motorways if im doing near 80 in fifth gear no problems yet between 60 and 70 in fifth and it can die 3 times on the trot.
I mis-read my own driving habits with this fault and replaced the cam sensor after reading posts on similar faults but was assuming it was when I put my car under load when all I was really doing is putting the foot down in 4th gear at less than 40mph.
I have a friend who lives 40 miles from me who's going to do a leak off test for me at the weekend on the injectors. Ive also replaced the fuel filter.
So guys before I go ahead and start cleaning MAF Sensor, EGR Valve and Inlet manifold, Any ideas??
Forgot to mention before the problems started I was getting 54 MPG I now get 61 so fuel economy is a lot better
Old Jul 11, 2013 | 12:35 PM
Rowe's Avatar
Rowe
Skint
have you had the fault codes read?
May be a duff crank sensor
Old Jul 11, 2013 | 12:42 PM
howdencomputers
Im waiting for code reader coming off Ebay they are Ł17 and im a computer engineer so gonna hook it u to laptop and take it for a drive to get live data from it.
Ive had crank sensor done about 2 years ago similar fault but never had all this trouble starting it would just randomly cut out
Old Jul 11, 2013 | 02:14 PM
Alvyn's Avatar
Alvyn
I'm going with the pump IS knackered! and the more you keep cranking the engine before it starts the more things will start to go wrong imo!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
