Unmolested cossie - should i chip it?
Old Mar 18, 2005 | 02:30 AM
nzcossie's Avatar
nzcossie
Default Unmolested cossie - should i chip it?
I have a 88 cossie (only crystal blue in NZ), done 117,000miles with a major engine rebuild at 95k (after the mechanic didnt tighten the cam belt). It was owned by a elderly guy b4 me who pampered it. Should i put a chip in with this mileage? Don't want to blow my baby up. If so which chip do you recommend?
Old Mar 18, 2005 | 08:17 AM
mick320BHP's Avatar
mick320BHP
give it a stage 3 chip a set of 803s injectors 3bar map sensor and a aftermarket exhaust and feel the power make sure to get it set up proparly and then kick some butt
Old Mar 21, 2005 | 02:05 AM
nzcossie's Avatar
nzcossie
Sounds expensive to me . What is the differnce in performance figures for the stages?
Old Mar 21, 2005 | 11:23 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Typically, stage 1 = 280, stage 2 (rare) = 300ish, stage 3 = 330, but this varies between tuners.
Stage 3 involves quite a bit more boost, stage 1 is a nice improvement, with a good aftermarket exhaust. Not a huge amount of stress on the car, noticeable performance difference. Prob best bet if you are worries about breaking things...
Saying that, mine's stage 1 on 114,000 miles without an engine rebuild and still going very strong.
Old Mar 21, 2005 | 11:29 AM
MadMac's Avatar
MadMac
Personally if its mint, I would leave it as is, far to many cossies are being modded and not many being kept standard.
But depends on where you want to go.
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
