Escort Cabriolet 1996 Help Question
Old Jun 1, 2013 | 07:29 PM
terencem215's Avatar
terencem215
Default Escort Cabriolet 1996 Help Question
New to this ford stuff, just bought a 1996 ford escort cabriolet 1.6 16v
So anyway im not sure what common faults are but this car runs fine until it gets hot, and then its juddering and almost cutting out when i press the throttle even slightly. The guy i bought it from said engine temp sensor, dono why that would make it run like that though... So i ak the ford boffins any ideas whats going on
Thanks
Old Jun 1, 2013 | 07:33 PM
stevos's Avatar
stevos
I would imagine if the sensor was faulty then the car would still think its cold even when warmed up. And probably over fuelling just my guess
Old Jun 1, 2013 | 07:49 PM
terencem215
thats what it feels like, either over fuelling or like its not getting enough fuel. Any idea why it would do this? or what needs replacing to fix the problem
Old Jun 1, 2013 | 07:52 PM
STeve's Avatar
Super Moderator
crank sensor or blocked/restricted breather even ISCV or TB
Old Jun 1, 2013 | 08:21 PM
terencem215
Crank sensor sounds like a good shout as it does idle rough and someone mentioned it the other day as common fault on the engine
Old Jun 1, 2013 | 08:49 PM
terry10w's Avatar
terry10w
Could be a breakdown in coilpack wen warm many different reasons it could do this also try unplug the maf sensor see if that makes a difference.
Old Jun 2, 2013 | 04:04 PM
terencem215
Thanks mate ill have try of the maf sensor and then I guess I'll see after that
FlashRS
Sep 14, 2015 12:36 PM
23
Sep 12, 2015 12:56 PM
Vincereese
Aug 18, 2015 03:57 PM
