Fuel system setup???
Old May 23, 2013 | 09:02 AM
RS16iDale's Avatar
RS16iDale
Default Fuel system setup???
Hi guys little bit unsure of what i need for my fuel setup?
The car was a escort 1.3 carb so still has that fuel tank.
It will be fitted with a 2litre zetec turbo roughly 250bhp at start,but want to up the power in future.
It will just be used as a fun weekend car and rwyb days.
I was thinking i need-
Lift pump,swirl pot,bosch 044 pump,fuel tank,inline filter?
Old May 23, 2013 | 09:10 AM
JonnyBravo's Avatar
JonnyBravo
You have basically covered what's required.
Ideally you should filter the lift pump although if you use a Facet red too for example they do have a replaceable filter inside them.
Old May 23, 2013 | 10:40 AM
RS16iDale's Avatar
RS16iDale
Ok great stuff so order would be in
Tank-lift pump-swirl pot-044 pump-engine
That correct? Do i have to use a different tank or can i run a lift pump from my standard tank?
Old May 28, 2013 | 12:34 PM
RS16iDale's Avatar
RS16iDale
Can i not just fit a 044 pump straight from my original carb tank then to the engine because idealy i dont want a big in car fuel setup?
Old May 28, 2013 | 04:03 PM
JonnyBravo's Avatar
JonnyBravo
No you can't as the tank has no internal swirl pot.
Old May 28, 2013 | 04:10 PM
RS16iDale's Avatar
RS16iDale
Ah i see ok,could i use a rs turbo tank and just external pump?
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
155lee
Oct 27, 2015 04:55 AM
Dubs44
Sep 19, 2015 06:31 AM
truffleshuffle
Sep 10, 2015 09:35 PM
ST-170
Sep 4, 2015 11:02 AM
