Big Brakes Help
Can any one help me out with my wilwood big brakes
I bought these from Burton Power that states these brakes are for a MK6 escort 283mm with 4 pot calipers kit
The problem I have is trying to sort these out as my ford brake line is diff from what the wilwood conector is
so I need some new ones made up, the problem I have is what size is this wilwood connector and what end of the connector goes into the wilwoods (the flat end or point end
I have the same setup as this below just not got my discs yet
This is the end that goes on the ford caliper
But it needs to look like the opposite end for the wilwoods
Also ford have brakets on their brake hoses to stop them rubbing on the wheels
So if anyone has any tips they can give me I would appreciate this
or even a guide
or even a guide
