Focus 1.8 zetec revving problem
Old May 6, 2013 | 04:12 AM
Paulflacky2's Avatar
Paulflacky2
Default Focus 1.8 zetec revving problem
Hyia im a newble to the site I've got a problem With my focus 1.8 zetec petrol it revs up ok at idle but when your driving it only revs up to 3000rpm and only do about 60 if u dip the clutch it revs up again it's had a new centre piece of the exhaust and backbox the cats ok just passed Mot could someone help thanks Paul sorry for the long winded post ha
Old May 6, 2013 | 08:00 AM
Paulflacky2
would the coil pack cause this fault I just can't get my head around it revs up ok
Old May 7, 2013 | 09:45 PM
studabear's Avatar
studabear
did you have the problem prior to the exhaust replacement?
Old May 8, 2013 | 12:31 PM
martysmartie's Avatar
martysmartie
What he ^^ said?
It sounds like there is a restriction, the reason it revs as you describe is as there is no load applied.
Martin
Old May 9, 2013 | 03:38 PM
Paulflacky2
Hyia thanks guys for the reply I found the silencer in the middle part had a faulty internal pipe blocking air flow under load I have had the bits changed on warranty and the car is spot on
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Dubs44
Aug 21, 2015 02:42 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
taylora1409
Aug 12, 2015 12:06 PM
gingerturbo
Aug 11, 2015 09:44 PM
