S2 starting and idling problems
Old Apr 22, 2013 | 06:26 PM
trackdaymad's Avatar
trackdaymad
Default S2 starting and idling problems
Hi, I have an 89 series 2 RS turbo running at about 200BHP and I am having problems with tick over/starting. The car starts when cold first turn of the key, will tick over for about 20 seconds and die. It will start again straight away but you have to keep feathering the throttle until the engine gets worm. Once the engine is worm it will tick over, but if you switch it off it won’t start again until it has cooled a bit. The engine revs good and clean, so I don’t think it’s mechanical. I have checked the ignition timing, fitted new plugs and fuel filter.
Can anyone shed some light on this problem?
Is this the cheapest place to get a cooling sensor? £61.19 seems a bit steep!
http://www.carpartsexpress.co.uk/RS-Range/Escort-RS-Turbo-Series-1-&-2/ENGINE-COMPONENTS/Cooling-System/Cooling-System-Sensors/p-49-225-227-577-508/
Conrad
Old Apr 22, 2013 | 06:29 PM
EoinXR3's Avatar
EoinXR3
Is it flooding when it won't start again?
Try holding the metering flap down a couple of mm while someone cranks it, it should start
Old Apr 22, 2013 | 06:36 PM
trackdaymad
Will give that a go tomorrow, if it does start, what would the most likely cause be?
cheers
Old Apr 23, 2013 | 06:18 AM
EoinXR3's Avatar
EoinXR3
Might be air leak
I'm sure someone with more knowledge will help yet
I had similar trouble turned out it was the ecu was connecting intermitinly and the accumulator, If you google it you'll get lots of ideas although you'll end up thinking everything's wrong!!
Old Apr 24, 2013 | 07:04 PM
trackdaymad
Default problems sorted
Tryed pushing down the metering flap and it made no diffrence. Found a breather pipe loose under the inlet manifold, this cured the tick over problems. There was filter in the vacum pipe for the dump valve, removed it and it now starts when hot. Not sure what this little filter is for? Does anyone know?
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Adam-M
22
Aug 10, 2015 10:46 AM
Zoggon
Aug 10, 2015 10:39 AM
