escort gti turbo boost problems
Old Apr 19, 2013 | 07:04 PM
escortgtit's Avatar
escortgtit
Default escort gti turbo boost problems
Hi, I own a 1998 escort gti, with turbo conversion, the mapping kit is megasquirt, and mapped on v-power fuel! the car has been running fine on boost, until this evening! i have just filled up with "supreme unleaded" could this be causing my issues which include..........
mapped to no boost, then at 4000rpm the turbo kicks in, but when this now happens, it holds back, like its fuel cutting, and backfires, although it sounds cool, it doesnt drive cool! could this be because of the mix, and diffeent fuel now used? should i run it just on v-power?
many thanks
Old Apr 19, 2013 | 08:10 PM
studabear's Avatar
studabear
sounds like you have another issue.
When was the turbo normally boosting?
Old Apr 19, 2013 | 08:29 PM
escortgtit's Avatar
escortgtit
I had it mapped the other week, set up to how it is, was honestly spot on before the fuel went in, have however noticed a strong fuel smell, and one of the injectors is leaking?
Old Apr 20, 2013 | 08:54 AM
Hobomassiv's Avatar
Hobomassiv
I had this on a RST running gotech management, as soon as it started boosting - No amount of threads here or anywhere else could point me to a simple list of what it could be.
So i stripped the car for rebuild. doh!
Old Apr 30, 2013 | 09:37 PM
escortgtit's Avatar
escortgtit
Ah, that wasn't good! Found the issue was a leaky Injector seal!
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
druidgetafix
Aug 15, 2015 10:22 AM
adriansaleem
Aug 1, 2015 09:28 PM
Escortdriver1
Jul 31, 2015 02:36 PM
