cossie bearing shells
Old Sep 22, 2003 | 07:47 PM
the original's Avatar
the original
Default cossie bearing shells
i'm doing a rebuild and need to get shells. want to make sure i get the best ones and not pinto ones (what is the difference?) what should be on the box- should it say cosworth? and what should they be made of? and where's a good place to get them?
reason i ask is the man who ground my crank (he was very old and talked in thou'!) said all the bearing making companies are owned by one huge company called federal mogul and that they just re-box two types of existing bearing to give the grooved/ plain combination. was he talking shit?
Old Sep 22, 2003 | 08:07 PM
Guinnless's Avatar
Guinnless
Unless you have a very early block Pinto shells don't fit. They should come in a Ford box. Stu should be able to supply them for you.
Old Sep 22, 2003 | 08:38 PM
the original
cheers Guinless. now i'm confused cos i thought 205 blocks were same as sierra injection and my cossie workshop manual says the crankshafts are dimensionally identical. where does the difference lie? (i can't stand not knowing something)
cheers
Old Sep 24, 2003 | 07:10 AM
John Vanlandingham's Avatar
John Vanlandingham
Yeah well the ol' geezer is very nearly right.
There's been so much aquisition and consolodation in the OEM and aftermarket supply world that I can't keep it straight myself, and the fact that these huge conglomerates continue to market stuff under old trade names doesn't help.
That said there are essientially 2 processes of tri-metal bearings remaining>
Clevite CL-77 and Vandervell's process.
Ford's OEM bearings are Glyco or is it Glacier so perhaps thats the same, in any case I have sat down and measured every concieveable dimension on both and see ZERO difference except the groove which holds some oil.
I am not aware from any book I have of different part numbers for different years of the 2000 Pinto block including the YB family.
Would be interesting to hear what the alleged difference are since I can see and measure none.
Old Sep 24, 2003 | 05:43 PM
Guinnless's Avatar
Guinnless
The block is the same but the mains caps are different. You can't swap mains caps around without having it all line bored.
HTH
Old Sep 26, 2003 | 03:44 AM
John Vanlandingham
Yeah OK but you can't swap caps from one block to another either, but the question was about the shells themselves, and I am curious what the diff is since i can't measure any.
Old Sep 26, 2003 | 07:35 AM
Guinnless's Avatar
Guinnless
Hmm I thought I said you can't swap the caps around
About 0.5mm wider IIRC.
Engines up to YBB1613 use the early shells and obviously YBB1614 onwards use the later type.
tankybaby66
Feb 6, 2016 02:24 PM
gambo08
Feb 4, 2016 10:49 PM
89barto89
Oct 4, 2015 06:59 PM
Fil
Sep 30, 2015 12:08 PM
20/20 vision
Sep 28, 2015 03:03 PM
