focus heater reisistor wiring question
Old Mar 24, 2013 | 08:59 AM
Daniel-1986's Avatar
Daniel-1986
Default focus heater reisistor wiring question
my heater resistor packed in last week and got 2 from a scrap yard 1 blue 1 white, the blue one packed in again so left with he white one but for how long is anyone's guess lol. I was told there's a modification to the wiring to stop them overheating and wondering what this was
Old Mar 24, 2013 | 11:59 AM
martysmartie's Avatar
martysmartie
What can happen is a poorly fitted pollen filter allows water inside and into the motor, this can then partically sieze the motor hence it burns the resistor packs out!
Martin
Old Mar 24, 2013 | 12:14 PM
Daniel-1986
Is there a way into the blower motor so I can put some grease in there and where is the pollen filter to check that
Old Mar 24, 2013 | 12:16 PM
martysmartie
You would have seen it when you dropped the glovebox it's right in front of you, but as I have said to you before usually you would notice as the passenger footwell would be wet, the problem isn't as much the filter but people don't use a new seal between the cover and the windscreen as they should, the motor is a bit of a pain to get out.
Martin
Old Mar 24, 2013 | 12:18 PM
Daniel-1986
I'll hav a look once this snow has cleared, gonna order a new resistor this week
Old Mar 30, 2013 | 10:45 AM
Daniel-1986
Got a brand new resistor (not genuine ford part) and fitted it, smoking quite heavily which is blowing in to the car wen the blowers on and wandering is it normal for them to do this being brand new including the genuine ford ones?
Old Mar 31, 2013 | 05:05 PM
martysmartie
Like I have said to you, it's more likely the motor causing it to heat up!
Martin
Old Mar 31, 2013 | 06:53 PM
Daniel-1986
I got my motor out, wasn't that hard to get out tbh, wen I spin the fan by hand it stops with in less than 2 seconds could this be too much resistance
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Sierrasideways
15
Aug 31, 2015 10:10 AM
borboyous
Aug 22, 2015 11:17 AM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
