Correct jets for a 1600 crossflow
Old Mar 20, 2013 | 01:42 PM
Pharaoh's Avatar
Pharaoh
Default Correct jets for a 1600 crossflow
Hi
Can anyone help, i have fitted a set of twin weber carbs on my 1600e cortina, i bought them second hand and just fitted them on, the engine is a standard 1558 crossflow with no modifications, not surprisingly it runs like a dog. Just had a bit of a read up and i think the carbs need to be jetted for that engine, this is where i'm lost.
Does anyone know the correct jets that should be fitted or am i asking the wrong questions here and should be doing something else. Any other advice would be very helpfull in setting this up right.
Old Mar 20, 2013 | 02:24 PM
co55iewife's Avatar
co55iewife
Im unsure about jetting but would be interested to know.
That aside though, clean engine bay!
Old Mar 21, 2013 | 09:54 AM
Alan77's Avatar
Alan77
motorsport nut job
Hi there,
Basic settings for webber twin 40 dcoe
Main jets 130-140
Air correctors 190-200
F11 emulsion tubes
35 accelerator pump jets
34mm chokes
4.5 auxiliary venturis
40 f9 idel jets
Float level shut off 7.5mm
Full droop float setting 15mm
I would service these first, kits are cheap
If you don't know much about these carb's i would get someone that does
There hard to set up and get right
Hope this helps
Alan
Old Mar 25, 2013 | 01:17 PM
porterste's Avatar
porterste
As said above good starting point for the crossflow engine but you really need to get it on a rolling road to get it set up right
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
chowfornow
14
Jan 5, 2019 09:01 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
mondeomark
Sep 28, 2015 06:28 AM
