Alarm problems!
Old Mar 14, 2013 | 09:01 PM
Daveybob77's Avatar
Daveybob77
Default Alarm problems!
Hoping someone can help with this! I have a Clifford intelliguard 950 on my Escort, it was installed by an approved installer, been fine for the previous owner and me up until tonight! Came back from meeting me misses from work, parked the car as normal on the drive, it sat there armed for over an hour, then it started making a warning sound, not a normal beep, more a squawk! every ten seconds or so? I've done the led flash zone thing but can't work out what they mean!? I know people don't rate Clifford, but I've had 'em before with no problems and think they're ok, and besides, i can't afford a new alarm so changing it isn't an option! I've checked all the doors, boot, bonnet and sunroof! Any help will be much appreciated as I've had to put it in valet mode for now!
Old Mar 14, 2013 | 09:33 PM
cossie891's Avatar
cossie891
Aint that the proxy sensor warning some one off it chirps if some one sets it off by being to close
Old Mar 14, 2013 | 09:49 PM
Daveybob77's Avatar
Daveybob77
Trouble is, i've parked it everyday in the same place on my drive for the last 6 months and it's been fine?! I stood out there and waited after I armed it and it made the warning sound! I can't work out the led sequence either! It flashed 3, 4, 7, 3, 3, 8!
Old Mar 14, 2013 | 10:00 PM
cossie891's Avatar
cossie891
Sorry I cat help mate as I know nothing about them
Old Mar 14, 2013 | 10:18 PM
B19 JUB's Avatar
B19 JUB
i fitted a clifford 650 to my orion last month and if i remember correctly the chirps every so often mean the fob battery is low.just a possibility in changing it
Old Mar 15, 2013 | 06:05 AM
Daveybob77's Avatar
Daveybob77
No worries fella! Cheers for the reply!
Old Mar 15, 2013 | 06:11 AM
Daveybob77's Avatar
Daveybob77
Yeah, already ordered some new batts! I'll post if that helps! Cheers mate!
Old Mar 16, 2013 | 05:34 PM
Daveybob77's Avatar
Daveybob77
Big jub was right! Key fob batteries changed and it's all sorted! Cheers for the replies!
Old Mar 30, 2013 | 10:21 AM
Daveybob77's Avatar
Daveybob77
Quick update on this! The new fob batteries worked for a day and a half! Then it started playing up again! I had to put it in valet mode until I could have a look at it! Had a look at it last Thursday. I took some of the interior apart to try and find the proxy sensor control box.. Took a couple of attempts to find it but i did! Turned the adjuster, tested it, turned it the other way, tested it, and so far so good! At least I didn't have to take it somewhere and pay over the odds! Good outcome in the end!
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
