Zetec head
Old Feb 27, 2013 | 07:21 AM
Shaun1.6ghia's Avatar
Shaun1.6ghia
Default Zetec head
So I've damaged my 1800 blacktop Zetec head so wondered how interchangeable the 2.0 head is as using the 2.0 cams in the 1800 head produce the 130 RS engine but have heard the compression ratio in the 2.0 head is lower.
Does anyone have any info on them?
If the valves are the same size?
If the compression is different? (If so what would I have to skim off to get it the same or even better)
Do they line up fine? (Oil and water ways)
Thank you guys
Old Mar 7, 2013 | 10:38 AM
haadee's Avatar
haadee
You would lower the CR to much with a 2.0 head, the valves are the same size.
Just get a new/other 1800 head fit the 2.0 cams and youre done
Old Mar 7, 2013 | 09:31 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
not checked personally, but have heard that 1800's have less volume in the head. i'm not convinced its the truth though. they do physically fit though, i'd give one a good skim (0.5mm ish) and stick it on. the difference in compression would barely be noticeable when driving.
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
RS-Rikki
Sep 21, 2015 07:27 AM
focuspower
Sep 20, 2015 03:51 AM
Chopshop85
Sep 18, 2015 06:13 AM
pie-face
Sep 15, 2015 10:43 AM
