2.0 dohb abs problem?
Old Feb 20, 2013 | 10:06 PM
gtcoupejc's Avatar
gtcoupejc
Default 2.0 dohb abs problem?
hey have a 92 2.0 dohc sierra, when driving at normal speed 30/40/50/60 etc and you hit the brakes the brakes work perfectly, but when at low speed in traffic etc and coming to a stop when you press the brake pedal the abs kicks in and the pedal vibrates away,
the abs fault light isnt lit up on the dash
any help would be greatly appreciatted!
thanks in advance
Old Feb 21, 2013 | 12:48 PM
martysmartie's Avatar
martysmartie
Common problem, first thing is to check all the sensors and rings are clean.
Otherwise there is something else that is causing a discrepancy in wheel speed.
I think the ABS light may only illuminate, if there is a problem.
Martin
Old Feb 21, 2013 | 01:52 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Dirty wheel sensor
Old Feb 21, 2013 | 05:38 PM
gtcoupejc's Avatar
gtcoupejc
ok thanks guys, ill get look at all the sensors this weekend! hopefully that sorts it
nico12
Dec 31, 2015 04:42 PM
Del gsxr
Sep 19, 2015 05:53 PM
cossiestu
Sep 19, 2015 05:19 AM
BENJAMIN_21
Ford Fiesta
Sep 17, 2015 08:58 AM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
