Breather bailey
Old Jan 22, 2013 | 09:50 PM
tonypastie's Avatar
tonypastie
Default Breather bailey
Hi Anybody no or have a diagram how to plumb this in escort cosworth I looked on google but all the plumbing I can find shows a catch tank but I don't have that
I bought a 2nd breather with the pipes etc I believe in the kit I have a right angled sump adaptor
Old Jan 22, 2013 | 11:22 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
You should be able to follow the instructions but where the catch tank is just breath it to atmosphere. Or put a little filter on it. Did you get a separator or breather?
Old Jan 23, 2013 | 07:44 AM
tonypastie's Avatar
tonypastie
I got the oil bailey pot and some hoses but no instructions
Old Jan 23, 2013 | 10:07 AM
H15 FSC's Avatar
H15 FSC
the 2 ports on the top go to .......( 2 choices ) 2nd choice is better but you will need some longer pipe and a fitting.
1)the rocker cover (need a port putting in), and the kidney box (under the OE breather, under inlet manifold.
2) on the left side of the block(by the sump lip) there is a bolt in the block that you remove and put a fitting in(not in the bailey kit), and the other to the kidney box under the inlet.
the little one at the bottom.... is the oil return, that go's to the sump, this must return under the oil level, you can T this into the std oil return from the kidney box( theres a metal pipe thats comes from the sump, to the bottom of the kidney box via a rubber pipe, this is on 4x4 cos only)
the big one at the bottom........ is the vent, now you can route this 2 ways, to a catch tank(mirror image tank etc) or vent it out under the car as far back as possible or it will smell oily in the car.
hope this helps . (oh also all the fittings are on ebay)
Old Jan 23, 2013 | 10:12 AM
H15 FSC's Avatar
H15 FSC
is it for the sump plug or the left block adaptor? the block one is quite a big bolt sized adaptor.
Old Jan 23, 2013 | 10:44 AM
tonypastie's Avatar
tonypastie
Thanks chap ill have a look later if I get any questions ill be back
Nov 1, 2015 06:53 PM
155lee
Oct 27, 2015 04:55 AM
