2.0 blacktop zetec flywheel clutch bolt PCD
Old 19-01-2013, 10:21 PM
Black Foci
Black Foci's Avatar
Default 2.0 blacktop zetec flywheel clutch bolt PCD
Im not sure if this is the correct section, but i could really do with some help on an issue i have. I have a 2.0 duratec engine in my car, and had a solid flywheel sent to me to fit it. Its a 240mm clutch flywheel, and the guy i got it from was unsure if it was machined to take a zetec pressure plate or a duratec pressure plate, or if it was for a completely custom clutch. It looks the same as a 2.0 zetec flywheel, with the lip around the edge.
I could really do with an old focus pressure plate or someone with a focus flywheel to measure the pcd of the pressure plate bolt holes & the pressure plate locating pins.
Thanks in advance for any help!
yatta
21-05-2016 10:31 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
hopper350
04-09-2015 12:53 AM
Quick Reply: 2.0 blacktop zetec flywheel clutch bolt PCD
